Loki and kubernetes gateway issues
Greetings!
I am currently trying to deploy Loki SSD on a local Kubernetes cluster following the SSD guide [Install the simple scalable Helm chart | Grafana Loki documentation]
Currently having it point to minio with nfs for testing, but will use on-prem S3 for production.
My issue is from the loki-gateway pod crashing with the below error:
/docker-entrypoint.sh: No files found in /docker-entrypoint.d/, skipping configuration
2024/06/24 13:25:01 [emerg] 1#1: host not found in resolver "kube-dns.kube-system.svc.cluster.local." in /etc/nginx/nginx.conf:33
nginx: [emerg] host not found in resolver "kube-dns.kube-system.svc.cluster.local." in /etc/nginx/nginx.conf:33
I have searched through many previous issues and their resolutions, basically suggesting that kube-dns should be coredns, or adding the clusterdomain and dnsnamespace parameters; although my Kubernetes instance has the coredns service name as kube-dns.
Our requirements is that we need to have Loki in Kubernetes externally accessible through our companies network, as we are purely on-prem with strict policies (banking).
We already have a monolithic Loki deployment on a VM for testing, and planning to integrate this SSD Loki deployment with our existing grafana-server (VM) and be able to push logs from promtail to Loki in Kubernetes.
Please let me know if I am missing anything, any help would be highly appreciated.
Here is my values.yaml file:
loki:
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: loki_index_
          period: 24h
  ingester:
    chunk_encoding: snappy
  tracing:
    enabled: true
  querier:
    # Default is 4, if you have enough memory and CPU you can increase, reduce if OOMing
    max_concurrent: 4
gateway:
  ingress:
    enabled: true
    hosts:
      - host: loki-gateway.default.svc.cluster.local
        paths:
          - path: /
            pathType: Prefix
deploymentMode: SimpleScalable
backend:
  replicas: 3
  persistence:
    enabled: true
    storageClassName: nfs-client
read:
  replicas: 3
  persistence:
    enabled: true
write:
  replicas: 3
  persistence:
    enabled: true
# Enable minio for storage
minio:
  enabled: true
  persistence:
    enabled: true
# Zero out replica counts of other deployment modes
singleBinary:
  replicas: 0
ingester:
  replicas: 0
querier:
  replicas: 0
queryFrontend:
  replicas: 0
queryScheduler:
  replicas: 0
distributor:
  replicas: 0
compactor:
  replicas: 0
indexGateway:
  replicas: 0
bloomCompactor:
  replicas: 0
bloomGateway:
  replicas: 0
Best Regards.
This has been fixed by adding the below to the helm chart:
global:
  dnsNamespace: kube-system
  clusterDomain: cluster.local
  dnsService: rke2-coredns-rke2-coredns
I’m seeing the same error. How did you determine what to put for those values?
Here’s an example of how to determine that: loki-simple-scalable loki-gateway Nginx startup failed · Issue #7287 · grafana/loki · GitHub
thanks a lot
