Loki - 429 Too Many Requests
I have the following error:
level=warn ts=2024-12-10T17:54:27.846382825Z caller=client.go:419 component=client host=loki:3100 msg="error sending batch, will retry" status=429 tenant= error="server returned HTTP status 429 Too Many Requests (429): Ingestion rate limit exceeded for user fake (limit: 4294967296 bytes/sec) while attempting to ingest '141644' lines totaling '28878236' bytes, reduce log volume or contact your Loki administrator to see if the limit can be increased"
This is my Loki code
auth_enabled: false
server:
  http_listen_port: 3100
  log_level: warn
  grpc_listen_port: 9095
common:
  path_prefix: /loki
  storage:
    s3:
      bucketnames: ${S3_BUCKET_NAME}
      region: ${AWS_REGION}
      access_key_id: ${AWS_ACCESS_KEY_ID}
      secret_access_key: ${AWS_SECRET_ACCESS_KEY}
  replication_factor: 1
  ring:
    kvstore:
      store: inmemory
schema_config:
  configs:
      store: tsdb
      object_store: s3
      schema: v13
      index:
        prefix: index_
        period: 24h
storage_config:
  aws:
    s3: s3://${S3_BUCKET_NAME}
    s3forcepathstyle: true
  boltdb_shipper:
    active_index_directory: /loki/index
    cache_location: /loki/boltdb-cache
limits_config:
  allow_structured_metadata: false
  reject_old_samples: true
  max_cache_freshness_per_query: 10m
  max_query_parallelism: 32
  max_entries_limit_per_query: 1000001
  ingestion_rate_mb: 3072
ingester:
  lifecycler:
    ring:
      kvstore:
        store: inmemory
  chunk_idle_period: 1m
  chunk_target_size: 1572864
  chunk_retain_period: 1m
compactor:
  working_directory: /loki/compactor
query_range:
  align_queries_with_step: true
  max_retries: 5
  parallelise_shardable_queries: true
table_manager:
  retention_deletes_enabled: true
  retention_period: 168h
query_scheduler:
  max_outstanding_requests_per_tenant: 2000
Anyone can help me?
