Im using logstash client with input file plugin to read the kubernetes logs from /var/log/** directory. I have also a log generator is running on a node, and grafana is unable to detect the log generator logs .Grafana is able to identify the datasource but containers is not listing. Below is my entire setup.
Source: logstash/templates/poddisruptionbudget.yaml
apiVersion: policy/v1
kind: PodDisruptionBudget
metadata:
labels:
app: “logstash-logstash”
chart: “logstash”
heritage: “Helm”
release: “logstash”
spec:
maxUnavailable: 1
selector:
matchLabels:
app: “logstash-logstash”Source: logstash/templates/configmap-pipeline.yaml
apiVersion: v1
kind: ConfigMap
metadata:
labels:
chart: “logstash”
heritage: “Helm”
release: “logstash”
data:
logstash.yml: |
http.host: “0.0.0.0”
log.level: debug
path.config: /usr/share/logstash/pipeline
logstash.conf: |
input {
file {
id => “varlog”
path => [“/var/log/**”]
type => “var log”
start_position => “beginning”
filter {
if [kubernetes] {
mutate {
add_field => {
“container_name” => “%{[kubernetes][container][name]}”
“namespace” => “%{[kubernetes][namespace]}”
“pod” => “%{[kubernetes][pod][name]}”
replace => { “host” => “%{[kubernetes][node][name]}”}
mutate {
remove_field => [“tags”]
}output { stdout { codec => rubydebug} loki { url => "http://loki-loki-distributed-distributor.loki-benchmark.svc.cluster.local:3100/loki/api/v1/push" } }
Source: logstash/templates/service-headless.yaml
kind: Service
apiVersion: v1
metadata:
labels:
chart: “logstash”
heritage: “Helm”
release: “logstash”
spec:
clusterIP: None
selector:
ports:
- name: http
port: 9600Source: logstash/templates/statefulset.yaml
apiVersion: apps/v1
kind: StatefulSet
metadata:
labels:
chart: “logstash”
heritage: “Helm”
release: “logstash”
spec:
serviceName: logstash-logstash-headless
selector:
matchLabels:
release: “logstash”
replicas: 1
podManagementPolicy: Parallel
updateStrategy:
type: RollingUpdate
template:
metadata:
labels:
chart: “logstash”
heritage: “Helm”
release: “logstash”
annotations:
pipelinechecksum: e5576a55d691ae22c1da1204f1e548e8aa936dc6415af52eb65699f5a155bb8
spec:
securityContext:
fsGroup: 1000
runAsUser: 1000
affinity:
podAntiAffinity:
requiredDuringSchedulingIgnoredDuringExecution:
- labelSelector:
matchExpressions:
- key: app
operator: In
values:
- “logstash-logstash”
topologyKey: kubernetes.io/hostname
terminationGracePeriodSeconds: 120
volumes:
- name: logstashpipeline
configMap:
- name: varlog
hostPath:
path: /var/log
- name: varlibdockercontainers
hostPath:
path: /var/lib/docker/containers
containers:
- name: “logstash”
securityContext:
capabilities:
drop:
- ALL
runAsNonRoot: true
runAsUser: 1000
image: “grafana/logstash-output-loki:1.0.1”
imagePullPolicy: “IfNotPresent”
livenessProbe:
failureThreshold: 3
httpGet:
path: /
port: http
initialDelaySeconds: 300
periodSeconds: 10
successThreshold: 1
timeoutSeconds: 5
readinessProbe:
failureThreshold: 3
httpGet:
path: /
port: http
initialDelaySeconds: 60
periodSeconds: 10
successThreshold: 3
timeoutSeconds: 5
ports:
- name: http
containerPort: 9600
resources:
limits:
cpu: 1000m
memory: 1536Mi
requests:
cpu: 100m
memory: 1536Mi
env:
- name: LS_JAVA_OPTS
value: “-Xmx1g -Xms1g”
- name: XPACK_MONITORING_ENABLED
value: “false”
volumeMounts:
mountPath: /usr/share/logstash/pipeline/logstash.conf
subPath: logstash.conf
- name: varlog
mountPath: /var/log
mountPath: /var/lib/docker/containers
readOnly: true
