I deployed Grafana on my Kubernetes Cluster using the latest Docker image and configured it with Azure File Storage credentials via a YAML file. Initially, I encountered a “Database is locked” error, which I resolved by following the steps outlined in this documentation: Deploying Grafana on Azure’s Web Apps for Containers.
After resolving the initial issue, I expected Grafana to run smoothly. However, I am now encountering a new error.
logger=query_data t=2023-12-11T11:20:31.431000046Z level=info msg="Query Service initialization"
logger=live.push_http t=2023-12-11T11:20:31.434538121Z level=info msg="Live Push Gateway initialization"
logger=infra.usagestats.collector t=2023-12-11T11:20:34.143352537Z level=info msg="registering usage stat providers" usageStatsProvidersLen=2
logger=provisioning.alerting t=2023-12-11T11:20:34.14365946Z level=info msg="starting to provision alerting"
logger=provisioning.alerting t=2023-12-11T11:20:34.143677162Z level=info msg="finished to provision alerting"
logger=http.server t=2023-12-11T11:20:34.146431975Z level=info msg="HTTP Server Listen" address=[::]:3000 protocol=http subUrl= socket=
logger=ngalert.state.manager t=2023-12-11T11:20:34.159491686Z level=info msg="Warming state cache for startup"
logger=grafanaStorageLogger t=2023-12-11T11:20:34.160370054Z level=info msg="Storage starting"
logger=ngalert.migration t=2023-12-11T11:20:34.187163929Z level=info msg=Starting
logger=ngalert.migration t=2023-12-11T11:20:34.187681569Z level=info msg="No migrations to run"
logger=grafana.update.checker t=2023-12-11T11:20:34.200659574Z level=info msg="Update check succeeded" duration=40.614445ms
logger=ngalert.state.manager t=2023-12-11T11:20:34.205791572Z level=info msg="State cache has been initialized" states=0 duration=46.297086ms
logger=ngalert.scheduler t=2023-12-11T11:20:34.205838676Z level=info msg="Starting scheduler" tickInterval=10s
logger=ticker t=2023-12-11T11:20:34.205968186Z level=info msg=starting first_tick=2023-12-11T11:20:40Z
logger=ngalert.multiorg.alertmanager t=2023-12-11T11:20:34.205914581Z level=info msg="Starting MultiOrg Alertmanager"
logger=plugins.update.checker t=2023-12-11T11:20:34.447035254Z level=info msg="Update check succeeded" duration=286.28837ms
logger=http.server t=2023-12-11T11:21:00.437161976Z level=error msg="Failed to parse user ID" error="identifier is not initialized"
logger=http.server t=2023-12-11T11:21:30.427328482Z level=error msg="Failed to parse user ID" error="identifier is not initialized"
logger=infra.usagestats t=2023-12-11T11:21:58.202838463Z level=info msg="Usage stats are ready to report"
logger=http.server t=2023-12-11T11:22:00.427223343Z level=error msg="Failed to parse user ID" error="identifier is not initialized"
logger=http.server t=2023-12-11T11:22:30.426791842Z level=error msg="Failed to parse user ID" error="identifier is not initialized"
logger=http.server t=2023-12-11T11:23:00.427485996Z level=error msg="Failed to parse user ID" error="identifier is not initialized"
logger=http.server t=2023-12-11T11:23:30.427250842Z level=error msg="Failed to parse user ID" error="identifier is not initialized"
