Hi Team,
I am trying to simulate a scenario where i have to open new session (without incognig).
Can you help to guide me to get it working
Hi Team,
Hi @arvind_patel, welcome to the forum! ![]()
If I understand correctly what you are trying to achieve is to create a new browser window that would inherit the session data already present in the browser instance? Is that correct?
If that is the case, unfortunately this is currently not supported, as, by default, when opening a new page, k6 browser implicitly creates a new browser context. We have a similar issue reported that you can use to keep track of this functionality.
I got a workaround by creating chrome user profile before launching tests
Here is another case that ruins a tester lifeā¦
My test consist a step that a file is downloaded. In incognito mode, a download verification modal is displayed and asks user where to download. In non-incognito mode itās not displayed and download starts right away. Iām setting "K6_BROWSER_ARGS=ādisable-model-download-verificationā " but it doesnāt work and disappear. So my work is ruined and I got stuck here for 10 hours! Iāve tried to apply many sort of workarounds but strictly limited to browser context. Is it really hard for you to give option to developers to switch between modes?!
Hi @ozgurcubuk,
We would like to get a better understanding of your use case. Do you have a test script that is pointing to a publicly accessible website?
Cheers,
Ankur
Hello @ankur,
Iām currently using k6/experimental/browser to conduct tests on a local HTML file that embeds an iframe. The iframe is responsible for loading a report, and my objective is to gather data on the number of xmlhttprequest the iframe is issuing.
Under normal circumstances, attempting such an operation would result in a cross-origin CORS issue. To prevent this, Iāve set the environment variable like below
$env:K6_BROWSER_ARGS =ādisable-web-security,user-data-dir=ā./temp-chrome-profileāā;
This is intended to disable web security features for testing purposes in the browser to allow cross-origin access to the iframe content.
However the browser is always launching in Incognito mode. My understanding is that certain flags, potentially including --disable-web-security, may not be fully respected in Incognito mode, which could be contributing to the difficulties Iām facing.
Is there any workaround on how to open the browser not in Incognito mode?
Thank you
Hi @krikeri,
Welcome to the forum!
Thank you for the detailed request and feedback. Iāve taken a look to see whether there is a way to open a browserContext in non incognito mode, unfortunately (as far as I can tell) there isnāt a way. We can start chrome without the no-startup-window flag which seems to open a window in non incognito mode but currently the k6 browser module cannot work with that window.
Have you had any luck in accomplishing the same thing using other frontend tools? Iād be keen to know if there is a tool that can run a test without incognito enabled.
Cheers,
Ankur
Hello @ankur,
Thank you for the explanation. I havenāt had a chance to test this myself, but based on the discussion in Issue #8836, it seems that Puppeteer opens a browser in non-incognito mode by default.
Cheers
Hi @krikeri,
thanks for the heads up on that! I took a quick look at Puppeteer and tried to replicate it in the k6 browser module. While my experiments showed some promising results where I was able to run a test in a non incognito window, for a final solution, it requires further discussion and possibly quite a lot of changes and many more test runs to validate the solution.
Iāve added a bit more detail in this comment on issue #891.
I canāt say when we will be able to take this further as we have quite a few other things to look into at the moment.
Thanks again for the feedback!
Ankur
