Kubernetes: monitoring a single namespace
I would like to monitor applications running in a single Kubernetes namespace, which includes:
  • prometheus metrics endpoints
  • pod logs ( written to the container’s stdout )
  • opentelemetry traces
Looking at the Helm chart ( k8s-monitoring 0.2.2 · grafana/grafana ) I don’t see any changes that I can make to configure the metrics scraping/log gathering to be confined to a single namespace. I guess gathering traces is a push mechanism so this is not an issue.
What options do I have for confining log gathering/metrics scraping to a single Kubernetes namespace?
Thanks!
Hi rombert!
I am one of the authors of the k8s-monitoring Helm chart. I just created an example of filtering to a specific list of namespaces. You can see that example here: https://github.com/grafana/k8s-monitoring-helm/tree/main/examples/specific-namespace
Also, pick up version 0.2.3, which improved some of the namespace handling I found when writing up that example.
Let me know if that works out, or if there’s anything else you might need!
-Pete Wall
Thanks a lot @petewall , this looks good! I tried deploying the k8s-monitoring helm chart to my target cluster but there is a CRD conflict with the kube-prometheus stack which I was not able to immediately solve. I am using FluxCD which may complicate things a bit.
I will keep trying and let you know.
Thanks!
Ah, seems values.prometheus-operator-crds.enabled is what I wanted to check.
Yep! That should tell the chart to skip deploying the CRDs.
One more questions @petewall . Since I am not using CRDs I tried to manually configure the grafana agent to scrape metrics from pods.
I added the following to my Helm values:
prometheus.scrape "pospai_pods" {
  targets = discovery.kubernetes.pods.targets
  forward_to = [prometheus.relabel.podmonitors.receiver]
This seems to work, but I see in the logs that it tries to scrape metrics from outside the configured namespace. I guess this is expected, as the extraMetricRelabelingRules parameter is not taken into account here.
Even when changing the scrape target to
  rule {
      source_labels = ["namespace"]
      regex = "^$|app-pospai"
      action = "keep"
I see other instances getting scraped. Can you suggest a way to exclude pods from other namespaces from being scraped?
Thanks again!
Gotcha!
So, instead of putting a rule in the prometheus.scrape component, you’ll need to add a discovery.relabel component with that rule. Also, the namespace label wont be set, so you’ll use the __meta_kubernetes_namespace label. You can see all of the meta labels that are set by discovery.kubernetes.pods from here: discovery.kubernetes | Grafana Agent documentation.
Reading through this doc might be helpful: https://github.com/grafana/k8s-monitoring-helm/blob/fix/doc-improvements/charts/k8s-monitoring/docs/ScrapeApplicationMetrics.md
