After completing the process to add Grafana to the K8s cluster, I’m seeing the KubeleteDown alert on the dashboard page. Does one need to create an access policy in addition to the access token?
Hi @conradwt - are you using the Kubernetes Monitoring tool? If so, that error means that the Kubelet has disappeared from Prometheus target discovery. Have there been any changes to the endpoint for Kubelet metrics?
You can also inspect the alert rules that are created for this tool for additional details.
