"failed to read cluster seed file" err="failed to get s3 object: NoSuchKey: The specified key does not exist.\n\tstatus code: 404, request id: YJK8G8Q59PFQX49M, host id: 3IWUZ96OPIWdYJ9p8+zMRoSCGT4bd872+HCZpubM04PSKxPR2d5WHekPW7ZKJbX70xeMTX3LBSs="
This is the error I am getting…But its uploaded one file with name loki_cluster_seed.json and with the contents
{"UID":"246af642-19c5-4dd7-9e41-a30155126a0a","created_at":"2024-09-10T10:50:31.869013055+05:30","version":{"version":"2.9.10","revision":"7664eda07b","branch":"HEAD","buildUser":"root@98f97496e533","buildDate":"2024-08-09T18:28:28Z","goVersion":"go1.22.5"}}
Blockquote
And my loki config file is
auth_enabled: false
server:
http_listen_port: 3100
log_level: debug
common:
ring:
instance_addr: 127.0.0.1
kvstore:
store: inmemory
replication_factor: 1
path_prefix: /loki
schema_config:
configs:
store: tsdb
object_store: s3
schema: v13
index:
prefix: index_
period: 24h
storage_config:
tsdb_shipper:
active_index_directory: /loki/index
cache_location: /loki/index_cache
aws:
bucketnames: loki-new
region: us-west-2
access_key_id: ****************************
secret_access_key: ***********************
insecure: false
http_config:
idle_conn_timeout: 90s
response_header_timeout: 0s
insecure_skip_verify: false
s3forcepathstyle: true
It automatically uploads that json file but gives an error…What might be the issue!
