I’m a bit lost on how to best use journald and log files in Loki, in practice.
- I started, as shown in the documentation, by putting the systemd-unit and the level of the message in labels. But then I read the “best practices”, and they strongly warn, not to do this, to keep cardinality low.
- So I removed them – but now these essential information are missing completely.
- So I enabled
json: truefor the journal-scraper, so that the information is packed into the log message. - But now I need to use the
jsonparser in LogQ to extract the relevant information. - But since my regular log files are not json, the json parser will not work for log lines from those, meaning I cannot use both the log lines of journald and of log files in the same query.
- To fix this, I tried to use the
packstage on the log files, so that these entries also become json - But while the json feature of the journal scraper puts the log message into the field named
MESSAGE, the pack stage uses_entryinstead. So I still cannot properly use both in the same query.
This all feels like a long chain of dirty hacks for a pretty basic task: search logs from the journal and from log lines. Am I missing something? How are you handling these issues?
