Hi
Is it possible to get both the current default summary and write the summary to json? When I define handleSummary the current summary isn’t outputted.
Thanks
Richard
Hi
Thanks
Richard
Hi there,
sure, just make sure to also specify the stdout
property in the returned object, and use the textSummary
function from the jslib. See the docs example.
