Hi all,
I have written a script for load testing my service The size of the script is > 256kB. I am facing a peculiar problem where in I if I supply parallelism as 5 to k6 operator out of 5 pods 2 pods fail with error :
time="2024-12-13T07:25:16Z" level=debug msg="Logger format: TEXT"
time="2024-12-13T07:25:16Z" level=debug msg="k6 version: v0.50.0 (go1.21.10, linux/amd64)"
time="2024-12-13T07:25:16Z" level=debug msg="Resolving and reading test '/test/authentication-utils.js'..."
time="2024-12-13T07:25:16Z" level=debug msg=Loading... moduleSpecifier="file:///test/authentication-utils.js" originalModuleSpecifier=/test/authentication-utils.js
time="2024-12-13T07:25:16Z" level=debug msg="Everything has finished, exiting k6 with an error!" error="The moduleSpecifier \"/test/authentication-utils.js\" couldn't be found on local disk. Make sure that you've specified the right path to the file. If you're running k6 using the Docker image make sure you have mounted the local directory (-v /local/path/:/inside/docker/path) containing your script and modules so that they're accessible by k6 from inside of the container, see https://grafana.com/docs/k6/latest/using-k6/modules/#using-local-modules-with-docker."
time="2024-12-13T07:25:16Z" level=error msg="The moduleSpecifier \"/test/authentication-utils.js\" couldn't be found on local disk. Make sure that you've specified the right path to the file. If you're running k6 using the Docker image make sure you have mounted the local directory (-v /local/path/:/inside/docker/path) containing your script and modules so that they're accessible by k6 from inside of the container, see https://grafana.com/docs/k6/latest/using-k6/modules/#using-local-modules-with-docker."
but the other 3 pods have the following log :
time="2024-12-13T07:25:16Z" level=debug msg="'/test/authentication-utils.js' resolved to 'file:///test/authentication-utils.js' and successfully loaded 993727 bytes!"
time="2024-12-13T07:25:16Z" level=debug msg="Gathering k6 runtime options..."
time="2024-12-13T07:25:16Z" level=debug msg="Initializing k6 runner for '/test/authentication-utils.js' (file:///test/authentication-utils.js)..."
time="2024-12-13T07:25:16Z" level=debug msg="Detecting test type for..." test_path="file:///test/authentication-utils.js"
time="2024-12-13T07:25:16Z" level=debug msg="Trying to load as a JS test..." test_path="file:///test/authentication-utils.js"
time="2024-12-13T07:25:16Z" level=warning msg="The source for `file:///test/authentication-utils.js` needs to go through babel but is over 256000 bytes. For performance reasons source map support will be disabled for this particular file."
time="2024-12-13T07:25:58Z" level=debug msg="Babel: Transformed" t=41.088758056s
time="2024-12-13T07:25:58Z" level=debug msg="Runner successfully initialized!"
time="2024-12-13T07:25:58Z" level=debug msg="Parsing CLI flags..."
time="2024-12-13T07:25:58Z" level=debug msg="Consolidating config layers..."
time="2024-12-13T07:25:58Z" level=debug msg="Parsing thresholds and validating config..."
time="2024-12-13T07:25:58Z" level=debug msg="Initializing the execution scheduler..."
time="2024-12-13T07:25:58Z" level=debug msg="Starting 1 outputs..." component=output-manager
time="2024-12-13T07:25:58Z" level=debug msg=Starting... component=metrics-engine-ingester
time="2024-12-13T07:25:58Z" level=debug msg="Started!" component=metrics-engine-ingester
time="2024-12-13T07:25:58Z" level=debug msg=" execution: local\n script: /test/authentication-utils.js\n output: -\n\n scenarios: (20.00%) 1 scenario, 3200 max VUs, 9m30s max duration (incl. graceful stop):\n * ramping_arrival_rate: Up to 1000.00 iterations/s for 9m0s over 9 stages (maxVUs: 200-3200, gracefulStop: 30s)\n\n"
time="2024-12-13T07:25:58Z" level=debug msg="Trapping interrupt signals so k6 can handle them gracefully..."
time="2024-12-13T07:25:58Z" level=debug msg="Starting the REST API server on 0.0.0.0:6565"
time="2024-12-13T07:25:58Z" level=debug msg="Starting emission of VUs and VUsMax metrics..."
time="2024-12-13T07:25:58Z" level=debug msg="Start of initialization" executorsCount=1 neededVUs=200 phase=execution-scheduler-init
as not all the pods start my test does not run
following is the configuration of runners :
apiVersion: k6.io/v1alpha1
kind: TestRun
metadata:
spec:
parallelism: {{workflow.parameters.parallelism}}
script:
volumeClaim:
file: {{workflow.parameters.scriptFileName}}
arguments: --tag testid={{workflow.parameters.testId}} --log-output=stdout --verbose
runner:
livenessProbe:
httpGet:
path: /v1/status
port: 6565
initialDelaySeconds: 60
periodSeconds: 30
timeoutSeconds: 25
failureThreshold: 6
successThreshold: 1
readinessProbe:
httpGet:
path: /v1/status
port: 6565
periodSeconds: 30
timeoutSeconds: 25
failureThreshold: 6
successThreshold: 1
securityContext:
runAsNonRoot: false
runAsUser: 0 # Run as root
fsGroup: 0 # Set file system group to root
resources:
limits:
cpu: 1000m
memory: 2048Mi
requests:
cpu: 1000m
memory: 2048Mi
volumes:
- hostPath:
path: /var/log/kaarya
volumeMounts:
- mountPath: /tmp
image: 578061096415.dkr.ecr.us-east-1.amazonaws.com/load-test:1.0.0
imagePullSecrets:
- name: dockercred
imagePullPolicy: Always
can some pls help me as to what is going on here
