Hey,
I have a question for the k6 public rest API. In the rest API you have private links (see image) but you need a login to use them any body know them? Note: I am using the localhost version from github: GitHub - grafana/test-api.k6.io: A simple REST and Websocket service designed for experimentation with k6
Hi @rubenkorse, welcome to the community forum!
There are predefined users. It is documented in the Readme: GitHub - grafana/test-api.k6.io: A simple REST and Websocket service designed for experimentation with k6
And you can also use the http://localhost:8000/user/register/ endpoint to register a new user.
I hope this helps
