Hello Team,
I am using k6 prometheus write extension to push metrics to cortex, As our cortex is using auth & need to pass X-Scope-OrgID . I can see the code supports it.
Howerver I need help to supply this information as a environment variable like K6_PROMETHEUS_REMOTE_URL .
How I can achieve same?
Hi @niravshah2705 , welcome to the community forum
I am not certain this is what you are asking, but if you just want access to env variables that is done through the __ENV object, so in your case __ENV.K6_PROMETHEUS_REMOTE_URL.
Is this what you wanted or did I misunderstand?
Thank you @mstoykov for your reply. I can setup exposed K6_PROMETHEUS_REMOTE_URL environment variable. & works well for me.
However I have to modify code & expose TenantName as environment variable, so that I dont have to change k6 scripts if I run locally or in our integrated environment.
Is there any default way to expose config via environment variables in plugins , I would like to do so too.
Regards,
Nirav Shah
You can do exactly the same - set env variable TENANT_NAME and use it as __ENV.TENANT_NAME internally.
If you are using k6 cloud you will need to use the -e option as in that case we don’t want to send all your env variables to the cloud.
I don’t know what you mean, but I guess the thing above? Although there are no such thing as plugins in k6. Do you mean extensions?
Hey @mstoykov , It does not work for me. Can you try if it is working as mentioned by you?
Yes, I mean extenstions. As I am not able to use mentioned environment variables. I think it has different pattern for naming conventions.
Hi @niravshah2705, can you please give some code sample that does not work for you?
All I am saying will 100% work and either you found some very complex bug or are doing a very small mistake somewhere. With a small code sample - in this case only the parts where you make the client, and how you run it - are enough, we will likely be able to debug it.
Hello @mstoykov
Please find steps I follow as below:
nirav@Niravs-MacBook-Pro ~/g/bin> export K6_PROMETHEUS_REMOTE_URL="https://cortex.dev.mycompany.com/api/v1/push"
nirav@Niravs-MacBook-Pro ~/g/bin> export TENANT_NAME="test"
nirav@Niravs-MacBook-Pro ~/g/bin> export K6_TENANT_NAME="test"
nirav@Niravs-MacBook-Pro ~/g/bin> ./k6_old run ~/testcase1.js -o output-prometheus-remote
/ __________ \ |__| \__\ \_____/ .io
INFO[0002] Prometheus: configuring remote-write with prometheus mapping
execution: local
script: /Users/nirav/testcase1.js
output: Output k6 metrics to prometheus remote-write endpoint
scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
* default: 1 iterations shared among 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
running (00m01.0s), 0/1 VUs, 1 complete and 0 interrupted iterations
default ✓ [======================================] 1 VUs 00m01.0s/10m0s 1/1 shared iters
█ Fetch a list of public crocodiles
✓ response status is 200.
✓ https://test-api.k6.io/public/crocodiles has valid json response
✓ number of crocs is greater than 4
✓ checks.........................: 100.00% ✓ 3 ✗ 0
data_received..................: 6.5 kB 6.4 kB/s
data_sent......................: 638 B 625 B/s
group_duration.................: avg=1s min=1s med=1s max=1s p(90)=1s p(95)=1s
http_req_blocked...............: avg=281.44ms min=20µs med=281.44ms max=562.86ms p(90)=506.57ms p(95)=534.71ms
http_req_connecting............: avg=101.62ms min=0s med=101.62ms max=203.25ms p(90)=182.92ms p(95)=193.08ms
http_req_duration..............: avg=217.51ms min=211.14ms med=217.51ms max=223.89ms p(90)=222.62ms p(95)=223.25ms
{ expected_response:true }...: avg=217.51ms min=211.14ms med=217.51ms max=223.89ms p(90)=222.62ms p(95)=223.25ms
http_req_failed................: 0.00% ✓ 0 ✗ 2
http_req_receiving.............: avg=1.78ms min=1.16ms med=1.78ms max=2.39ms p(90)=2.27ms p(95)=2.33ms
http_req_sending...............: avg=665µs min=105µs med=665µs max=1.22ms p(90)=1.11ms p(95)=1.16ms
http_req_tls_handshaking.......: avg=104.7ms min=0s med=104.7ms max=209.4ms p(90)=188.46ms p(95)=198.93ms
http_req_waiting...............: avg=215.07ms min=207.51ms med=215.07ms max=222.62ms p(90)=221.11ms p(95)=221.86ms
http_reqs......................: 2 1.958484/s
iteration_duration.............: avg=1s min=1s med=1s max=1s p(90)=1s p(95)=1s
iterations.....................: 1 0.979242/s
vus............................: 1 min=1 max=1
vus_max........................: 1 min=1 max=1
ERRO[0004] Failed to store timeseries. error="server returned HTTP status 401 Unauthorized: no org id"
Note here: as cortex we have enabled auth with below, it expects client_name environment variable:
config:
auth_enabled: true
We are getting 401 as the variables defined are not passed to the command.
I don’t see a code sample @niravshah2705 so there is nothing for me to check. Please provide some code sample that reproduces the issue for you - you can remove the names or tokens as needed.
@mstoykov Thanks for help. Now I figured out pattern of parameter passing for the extensions.
./k6 run ~/testcase1.js -o ‘output-prometheus-remote=url=https://cortex.dev.mycompany.com/api/v1/push,headers.X-Scope-OrgID=k6’
nirav@Niravs-MacBook-Pro ~/g/bin> export K6_PROMETHEUS_REMOTE_URL=“https://cortex.dev.mycompany.com/api/v1/push”
nirav@Niravs-MacBook-Pro ~/g/bin> ./k6 run ~/testcase1.js -o ‘output-prometheus-remote=headers.X-Scope-OrgID=k6’ -v
env ‘K6_PROMETHEUS_HEADERS_X-Scope-OrgID=k6’ ./k6 run ~/testcase1.js -o output-prometheus-remote
All above worked for me. I was looking for wrong extension code, hence expecting wrong parameter !!
