I am testing the k6-operator using EKS on AWS. I was following the official instruction. However the executor pod kept failing apart due to the issue with ipv6. Does k6-operator support ipv6?
The error msg shows " curl: (3) URL rejected: Port number was not a decimal number between 0 and 65535" in the pod.
I see the curl command uses ipv6 when I describe the pod. I think this is the root cause of the pod failure.
curl --retry 3 -X PATCH -H 'Content-Type: application/json' http://fdfe:d15b:965c::905a:6565/v1/status -d '{"data":{"attributes":{"paused":false,"stopped ││ ":false},"id":"default","type":"status"}}'
Below is my conf.yaml file
apiVersion: k6.io/v1alpha1
kind: TestRun
metadata:
spec:
parallelism: 1
# cleanup: post
arguments: -o experimental-prometheus-rw --tag testid=test
script:
configMap:
file: test.js
runner:
env:
- name: K6_PROMETHEUS_RW_SERVER_URL
value: "http://prometheus-kube-prometheus-prometheus.monitor.svc.cluster.local:9090/api/v1/write"
- name: K6_PROMETHEUS_RW_TREND_AS_NATIVE_HISTOGRAM
value: "true"
Looks like it’s a known issue as the status of this issue is still “Open”. It’s been over 2 years since the issue was open. Wondering if there is any update or workaround.
