This is the Command on Github Action
K6 run smokeTest.js --iterations 200 --duration 100m --vus 199
and its got killed after 133
Hi @dassusovan3, Welcome to the forum ![]()
Give what you provide I would expect that it runs out of memory which given that github machines apparently have 7GB of memory means that you have some pretty heavy VUs and/or use an older version of k6.
You can confirm this by running the command locally (with less VUs) and see how much memory it uses for example with 100 VUs.
I would expect that you either import a lot of js code and/or you have big data files for which you don’t use SharedArray.
If you can provide some additional info on what your script is doing or/and script code, we might be able to give more concrete advice.
Hope this helps you
