I am trying to Install K6 on Red Hat system.
Following the commands as per the installation guide of k6 against Red Hat/CentOS.
This installation is not going through, with the errors below. Is there a way to overcome this problem?
Please do re-direct me to any other thread that might have this already answered.
https://download.postgresql.org/pub/repos/yum/9.4/redhat/rhel-7-x86_64/repodata/repomd.xml: [Errno 14] HTTPS Error 404 - Not Found
Hi @prasoon,
This seems unrelated to k6.
As far as I can see postgresql has dropped the redhat repo for postgresql 9.4. You should probably either update that repo or remove it.
On the other hand (at least on fedora) this would not stop the process of installing an unrelated piece of software
Can you provide what steps you have taken to install k6 and what is the full output of yum
I am following the steps which K6 is suggesting
https://k6.io/docs/getting-started/installation
@prasoon , I propose you follow w/e it says on that wiki article that is referenced in the error message.
Again this is not about k6, you have a yum repo that is not currently supported, probably because it is too old and you installation hasn’t been updated to not use it in a while.
