K6 installation failing in mac
Hi, I am running the command ‘brew install k6’ but it gives an error
(base) $ brew install k6
==> Downloading https://ghcr.io/v2/homebrew/core/k6/manifests/0.33.0
Already downloaded: /Users//Library/Caches/Homebrew/downloads/fb9432f722f2a1a0dde633e8f6fe03297eb60ac63557a0c30582ef1f4d74dc03–k6-0.33.0.bottle_manifest.json
Error: Failed to download resource “k6_bottle_manifest”
The downloaded GitHub Packages manifest was corrupted or modified (it is not valid JSON):
Can someone help please.
Thanks,
Santosh
hmm this seems like a problem with homebrew on your side, we couldn’t replicate it on our end :confused:
maybe try running brew cleanup - https://www.educative.io/edpresso/what-is-brew-cleanup ?
I managed it using docker.
