K6 Docker Container initialization failed in Azure pipeline
While running using k6 docker container in Azure Pipeline - getting error
Following in my docker file
FROM joined-docker.artifactory.abcdefgg.net/grafana/k6:0.50.0
RUN apt-get update
COPY . /app
USER root
RUN echo $NODE_EXTRA_CA_CERTS
Following is my yml file
trigger:
  • master
pool:
stages:
  • script: chmod uga+rwx -R k6Report
  • script: ls -ltr
  • script: pwd
  • script: k6 run ./Basic_feeXpart_GET.js
  • script: docker run -it --rm
Error:
2024-05-23T08:38:32.6517873Z 9f89d995513a86b3cffe141920e151829e782234babeba0a61c4f149f92c0021 Up Less than a second
2024-05-23T08:38:32.6579027Z ##[command]/usr/bin/docker exec 9f89d995513a86b3cffe141920e151829e782234babeba0a61c4f149f92c0021 sh -c “command -v bash”
2024-05-23T08:38:32.7412942Z Error response from daemon: Container 9f89d995513a86b3cffe141920e151829e782234babeba0a61c4f149f92c0021 is not running
Hey @subp,
you should try to provide more context, your problem is very specific to how to run applications with Docker and Azure Pipeline, which is a bit far from the goal of the forum here.
The error doesn’t seem related to k6. You should at least try to isolate the problem from Azure Pipeline. Does it work if you run it locally using Docker?
Thanks.
Hi
Thanks for replying.
No when I tried to run it locally with same k6 image - fails too.
But with same process other docker images of like playwright passes.
Regards
If the Dockerfile used is the one posted in the original topic then I don’t see how it can work.
Why do you expect your Docker container should work just by doing RUN echo $NODE_EXTRA_CA_CERTS?
