When run the following k6 with browser test,
docker run --platform linux/amd64 --rm -i -v $(pwd):/home/k6/screenshots -e K6_BROWSER_HEADLESS=false grafana/k6:latest-with-browser run - <script.js
which script.js same as sample in Running browser tests (k6.io)
I got the following error:
/ __________ \ |__| _\ ____/ .io
execution: local
script: -
output: -
scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
* ui: 1 iterations shared among 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
time=“2024-04-20T00:08:38Z” level=error msg=“process with PID 21 unexpectedly ended: exit status 1” category=browser elapsed=“0 ms” source=browser
data_received........: 0 B 0 B/s
data_sent............: 0 B 0 B/s
iteration_duration...: avg=751.08µs min=751.08µs med=751.08µs max=751.08µs p(90)=751.08µs p(95)=751.08µs
iterations...........: 1 2.886941/s
running (00m00.3s), 0/1 VUs, 0 complete and 1 interrupted iterations
ui ✗ [ 100% ] 1 VUs 00m00.3s/10m0s 1/1 shared iters
time=“2024-04-20T00:08:39Z” level=error msg=“error building browser on IterStart: launching browser: Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory at file:///-:16:15(0)”
Environment is MacBook M3 OS 14.4.1.
Without using docker the browser has no issue to pop up. But when using docker it just doesn’t work. Because it is a company laptop, we will not have permission to access system_bus_socket. Even we do, I don’t think it is a good idea to expose system socket.
So the solution seems need to rebuild docker to deal with this issue? Any tips?
