Grafana 9.1.1, Windows 10.0.19044 Build 19044 -
I am configuring JWT authentication. And particularly signature verification. -
I configure
jwk_set_url = https://localhost:<rest part of URL> -
What happened?
On opening Grafana it shows error"Get \"https://localhost:<rest part of URL>\": x509: certificate signed by unknown authority"
This error should not happen because I set option
[auth.generic_oauth]
tls_skip_verify_insecure = true
What option I can change to make jwk_set_url https running?
UPD. If I download data from URL and use it in jwk_set_file then JWT verification works so it is not a problem of JWKS format.
