Hello Alexander and the community!
Is there any way to change this behavior or is this controlled in the code? Any help would be much appriciated.
Here’s the error I get. I had this problem in both 4.1.5 and 4.2.10.
Here’s my actual data in zabbix:
(https://user-images.githubusercontent.com/49399656/209290312-cdadba28-d61f-40dd-8403-41fbd8256671.png)
Here’s the actual api response from Postman:
https://user-images.githubusercontent.com/49399656/209290663-100ce19d-8e7a-45f1-b0dc-9d59eafe885c.png)
We’re using 9.0.3 Grafana in a local docker environment with 4.2.10 Zabbix Plugin. -
I’ve been struggling to use web.page.get items in a dashboard in grafana. My problem is that my item type is string but the pluging tries to convert it to float I think. -
I’m using ItemID query type with no -
What happened?
I couldn’t get any data in table or any other panel type. -
I expected it to look like in zabbix dashboard’s plain text type. -
They are visible in the screenshots but we are using only the API, no direct DB connections or anything else.
In UI, I have the log: “json: invalid use of ,string struct tag, trying to unmarshal…” -
No, I did not.
