We use a helm chart to do this . your support is more appreciated , Thank you again!
/\ Grafana /‾‾/
/\ / \ |\ __ / /
/ _______ \ |_|\_\ \__/
execution: local
script: vpe-default-k6-browser_gt-dev.js
output: -
scenarios: (100.00%) 1 scenario, 1 max VUs, 4m30s max duration (incl. graceful stop):
* browser_test: 1 looping VUs for 4m0s (gracefulStop: 30s)
running (0m01.0s), 1/1 VUs, 0 complete and 0 interrupted iterations
browser_test [ 0% ] 1 VUs 0m01.0s/4m0s
running (0m02.0s), 1/1 VUs, 0 complete and 0 interrupted iterations
browser_test [ 1% ] 1 VUs 0m02.0s/4m0s
running (0m03.0s), 1/1 VUs, 0 complete and 0 interrupted iterations
browser_test [ 1% ] 1 VUs 0m03.0s/4m0s
running (0m04.0s), 1/1 VUs, 0 complete and 0 interrupted iterations
browser_test [ 2% ] 1 VUs 0m04.0s/4m0s
time=“2025-09-05T14:57:21Z” level=error msg=“process with PID 24 unexpectedly ended: signal: trace/breakpoint trap (core dumped)” category=browser elapsed=“0 ms” source=browser
time=“2025-09-05T14:57:21Z” level=info msg=“[k6-reporter v2.3.0] Generating HTML summary report” source=console
time=“2025-09-05T14:57:22Z” level=error msg=“failed to handle the end-of-test summary” error=“Could not save some summary information:\n\t- could not open ‘browser-report.html’: open browser-report.html: permission denied\n\t- could not open ‘browser-summary.json’: open browser-summary.json: permission denied\n\t- could not open ‘browser-summary.html’: open browser-summary.html: permission denied”
running (0m04.2s), 0/1 VUs, 0 complete and 1 interrupted iterations
browser_test ✗ [ 2% ] 1 VUs 0m04.0s/4m0s
time=“2025-09-05T14:57:22Z” level=error msg=“error building browser on IterStart: launching browser: recvmsg: Connection reset by peer (104) at default (file:///app/k6/vpe-default-k6-browser_gt-dev.js:42:16(0))”
podman run --rm --shm-size=1g docker-gcg-dev-local.artifactrepository.citigroup.net/gcg-gcb-vpe-173456/k6-test:base-20250905-095239
WARNING: image platform (linux/amd64) does not match the expected platform (linux/arm64)
/\ Grafana /‾‾/ /\ / \ |\ __ / /
/ / \ | |/ / / ‾‾\/ \ | ( | (‾) |/ __________ \ ||_\ ____/
execution: local script: vpe-default-k6-browser_gt-dev.js output: - scenarios: (100.00%) 1 scenario, 1 max VUs, 1m30s max duration (incl. graceful stop): * browser_test: 1 looping VUs for 1m0s (gracefulStop: 30s)
running (0m01.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 2% ] 1 VUs 0m01.0s/1m0s
running (0m02.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 3% ] 1 VUs 0m02.0s/1m0s
running (0m03.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 5% ] 1 VUs 0m03.0s/1m0s
running (0m04.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 7% ] 1 VUs 0m04.0s/1m0s
running (0m05.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 8% ] 1 VUs 0m05.0s/1m0s
running (0m06.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 10% ] 1 VUs 0m06.0s/1m0s
running (0m07.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 12% ] 1 VUs 0m07.0s/1m0s
running (0m08.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 13% ] 1 VUs 0m08.0s/1m0s
running (0m09.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 15% ] 1 VUs 0m09.0s/1m0s
running (0m10.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 17% ] 1 VUs 0m10.0s/1m0s
running (0m11.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 18% ] 1 VUs 0m11.0s/1m0s
running (0m12.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 20% ] 1 VUs 0m12.0s/1m0s
running (0m13.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 22% ] 1 VUs 0m13.0s/1m0s
running (0m14.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 23% ] 1 VUs 0m14.0s/1m0s
running (0m15.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 25% ] 1 VUs 0m15.0s/1m0s
running (0m16.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 27% ] 1 VUs 0m16.0s/1m0s
running (0m17.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 28% ] 1 VUs 0m17.0s/1m0s
running (0m18.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 30% ] 1 VUs 0m18.0s/1m0s
running (0m19.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 32% ] 1 VUs 0m19.0s/1m0s
running (0m20.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 33% ] 1 VUs 0m20.0s/1m0s
running (0m21.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 35% ] 1 VUs 0m21.0s/1m0s
running (0m22.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 37% ] 1 VUs 0m22.0s/1m0s
running (0m23.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 38% ] 1 VUs 0m23.0s/1m0s^Crunning (0m24.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 40% ] 1 VUs 0m24.0s/1m0s
running (0m25.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 42% ] 1 VUs 0m25.0s/1m0s
running (0m26.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 43% ] 1 VUs 0m26.0s/1m0s
running (0m27.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 45% ] 1 VUs 0m27.0s/1m0s^Crunning (0m28.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 47% ] 1 VUs 0m28.0s/1m0s
running (0m29.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 48% ] 1 VUs 0m29.0s/1m0s
running (0m30.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 50% ] 1 VUs 0m30.0s/1m0s
running (0m31.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 52% ] 1 VUs 0m31.0s/1m0s
running (0m32.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 53% ] 1 VUs 0m32.0s/1m0s
running (0m33.0s), 1/1 VUs, 0 complete and 0 interrupted iterationsbrowser_test [ 55% ] 1 VUs 0m33.0s/1m0s
