I am using postman-to-k6 to convert my postman tests to k6. I am having issues running the converted script on cloud
Error on cloud: Aborted script error Archive validation failed for test_run_id=749816: The 'iterations' option is currently not supported for cloud runs. (4000)
I have lots of data to be tested and lots of apis. How do I run the postman converted scripts on K6 cloud ?
Command used to convert
postman-to-k6 collection.json --json data.json -e environment.json -o k6_script.js
some sample data is as follows:
     "article_id": 1301212,
     "unique_id": "b3f14503-e1e8-5200-94f4-d7378f6d135f",
     "randomText": "Incredible Rubber Mouse Thu Jun 11 2020 13:24:36"
     "article_id": 1301211,
     "unique_id": "cc21cb0d-805e-5b19-bef3-00b5d125c03d",
     "randomText": "Engineer middleware Fri Jun 12 2020 05:52:39"
     "article_id": 1301209,
     "unique_id": "a7023caa-9796-57fe-90d2-fec519dc89c1",
     "randomText": "generate Dynamic Fri Jun 12 2020 11:09:30"
This sample data contains 1000 unique_id’s
One of the request which i am sending in postman is as follows
curl --location --request GET 'https://<myurl>/public/comment/latest?articleId={{unique_id}}'
excerpts from converted_k6_script.js
     const file = (() => {
      // Load data file
      const text = open("./data.json");
      const rows = JSON.parse(text);
      return rows;
    options.iterations = file.length;
    const Iteration = Symbol.for("iteration");
    export default function() {
      postman[Iteration]();
      postman[Request]({
 ) doesn’t support running just iterations in it. The currently supported options are using
