Issues After Upgrading to grafana 7 - MS SQL data souce does not works on hostname\instance
After upgrading to grafana 7, I cannot add new MS SQL Data Source on hostname\instance.
The error is validation error, invalid URL hostname\instance. . note that there are two (\) in the error meaasge
Can you please suggest?
Thanks
Siddhartha Ganguly
Some updates have been made on the datasource URL validation checks and it seems like a regression. Could you report this in the Grafana repo (https://github.com/grafana/grafana) please?
Thank you for the reply. I reported this as per Issues After Upgrading to grafana 7 - MS SQL data souce does not works on hostname\instance · Issue #25310 · grafana/grafana · GitHub
Thanks
Siddhartha Ganguly
