Hello Grafana Community,
I’m facing an issue with my Grafana dashboard where I’ve set up two variables of type query
. One of the variables works as expected, but the other doesn’t run automatically unless I manually trigger it from the settings.
Issue:
- I have two query-based variables on my dashboard.
- The first variable’s query runs and populates the values automatically.
- However, the second variable does not run unless I manually go into the variable’s settings and run the query from there.
- This is causing a problem as the second variable doesn’t populate its values until I intervene.
Network Tab :
Console Tab :
- **Grafana Version: 9.2.0
- Data Source: Microsoft SQL Server
Has anyone experienced similar behavior where one query-based variable doesn’t run automatically? Are there any known workarounds or settings I should check to ensure both queries are triggered upon loading the dashboard?
Any guidance would be greatly appreciated!
