Hi. I want to deploy loki 3 Node on-premise.
In QA environment , I planed like this.
Grafana
Loki-Read Loki-Write Loki-Write
Cassandra Cassandra Cassandra
Consul Consul Consul
[Server 1] [Server 2] [Server 3]
In such environment, Externel Log writer (like promtail or td-agent) write logs to the Loki-write through Load balancer or dnsRR. Loki-write which received logs will store in the cassandra.
Anyone who want to see the logs can see on grafana on Server 1.
I have problem storing logs from Loki-write to cassandra. so, I have wonder this structure is right way.
Cassandra have loki keyspace. but Any table is not generate by loki.
loki generate log like this
{"caller":"logging.go:67","level":"debug","msg":"POST /loki/api/v1/push (204) 1.348687ms","orgID":"fake","traceID":"4edd698b4830ff99","ts":"2022-01-18T00:59:01.83376993Z"}
My configuration in Loki-write
target: write
distributor:
ring:
kvstore:
store: consul
consul:
host: {server-1}:8500
ingester:
lifecycler:
address: 192.168.0.208
ring:
kvstore:
store: consul
consul:
replication_factor: 2
final_sleep: 0s
interface_names:
- "eth0"
chunk_idle_period: 1m
chunk_retain_period: 30s
schema_config:
configs:
store: cassandra
object_store: cassandra
schema: v11
index:
prefix: loki_index_
period: 360h
chunks:
prefix: chunk
period: 360h
storage_config:
cassandra:
addresses: 192.168.0.206, 192.168.0.207, 192.168.0.208
auth: true
username: cassandra
password: cassandra
keyspace: loki
timeout: 10s
connect_timeout: 10s
table_manager:
retention_deletes_enabled: true
retention_period: 336h
creation_grace_period: 10m
Please let me know about loki best way clustered structure not using public cloud storage like S3.
