Hi, I’m trying to find a way to store all of the labels on my k8s pods in their logs, without adding loads of labels.
I can add everything as labels using:
- action: labelmap
regex: __meta_kubernetes_pod_label_(.+)
However, I want to avoid introducing loads of labels that I don’t necessarily need. The pack transform stage looks like it would help; however, it does not accept regex.
If I could do something like the following it would be perfect:
pipeline_stages:
pack:
labels:
- __meta_kubernetes_pod_label_(.+)
Is there any way to do something similar today using promtail?
