I need a excuter type or option. When I add two user ,one user run all the scenerios,and other user should run the all scenerios parallel. I want it to run all scenarios from two separate branches at the same time. For exeamle one VU sould run below scenerio,on the other hand other VU should run the below scenerio at the same time with first VU
export const options = {
scenarios: {
CreatePicking: {
executor: 'shared-iterations',
exec: 'CreatePicking',
vus: 2,
iterations: 2
export function CreatePicking(data) {
let createdIsCompleted = false;
let generateTokenHeader = {
headers: {
'Authorization': `Bearer ${data.access_token}`,
'content-type': 'application/json',
describe('Continue pick', (t) => {
let continueIfExistRes = http.post(requestUrlAPI + 'PickingProcessTest', JSON.stringify({
trolleyLabel:'PCK-TRL-L-0' + (vu.idInTest-1)
}), generateTokenHeader
t.expect(continueIfExistRes.status).toEqual(200);
sleep(1)
describe('check test', (t) => {
while (createdIsCompleted == false) {
let checkCellRes = http.post(requestUrlAPI + 'PickingProcess.checkCell', JSON.stringify({
cellLabel: `${cellLabel}`,
pickingReferenceNumber: `${pickingProcessReferenceNumber}`,
allocatedItemId: `${allocatedItemId}`,
}), generateTokenHeader)
console.log("checkCellControlRes", checkCellRes.body)
t.expect(checkCellRes.status).toEqual(204);
sleep(1)
