Hi All,
the default for the grafana database is mysql, postgre and sqlite3, i have option to use singlestore database as the database of grafana, but so many error because of the limitation of singlestore i assume, rather than to create new env which is more resources, i have singlestore cluster with ten nodes which is can be use if it can.
This is the error logs when i start the grafana-server service :
sql=“CREATE UNIQUE INDEX UQE_user_login
ON user
(login
logger=settings t=2023-04-03T13:14:55.491132195+07:00 level=info msg=“Starting Grafana” version=9.4.3 commit=cf0a135595 branch=HEAD compiled=2023-03-03T03:28:42+07:00
logger=settings t=2023-04-03T13:14:55.491395594+07:00 level=warn msg=“"sentry" frontend logging provider is deprecated and will be removed in the next major version. Use "grafana" provider instead.”
logger=settings t=2023-04-03T13:14:55.491430718+07:00 level=info msg=“Config loaded from” file=/usr/share/grafana/conf/defaults.ini
logger=settings t=2023-04-03T13:14:55.491445811+07:00 level=info msg=“Config loaded from” file=/etc/grafana/grafana.ini
logger=settings t=2023-04-03T13:14:55.491458738+07:00 level=info msg=“Config overridden from command line” arg=“default.paths.data=/var/lib/grafana”
logger=settings t=2023-04-03T13:14:55.491471588+07:00 level=info msg=“Config overridden from command line” arg=“default.paths.logs=/var/log/grafana”
logger=settings t=2023-04-03T13:14:55.491489112+07:00 level=info msg=“Config overridden from command line” arg=“default.paths.plugins=/var/lib/grafana/plugins”
logger=settings t=2023-04-03T13:14:55.491501609+07:00 level=info msg=“Config overridden from command line” arg=“default.paths.provisioning=/etc/grafana/provisioning”
logger=settings t=2023-04-03T13:14:55.491513632+07:00 level=info msg=“Path Home” path=/usr/share/grafana
logger=settings t=2023-04-03T13:14:55.491527101+07:00 level=info msg=“Path Data” path=/var/lib/grafana
logger=settings t=2023-04-03T13:14:55.491539986+07:00 level=info msg=“Path Logs” path=/var/log/grafana
logger=settings t=2023-04-03T13:14:55.491551893+07:00 level=info msg=“Path Plugins” path=/var/lib/grafana/plugins
logger=settings t=2023-04-03T13:14:55.491564169+07:00 level=info msg=“Path Provisioning” path=/etc/grafana/provisioning
logger=settings t=2023-04-03T13:14:55.491576116+07:00 level=info msg=“App mode production”
logger=sqlstore t=2023-04-03T13:14:55.491649514+07:00 level=info msg=“Connecting to DB” dbtype=mysql
logger=migrator t=2023-04-03T13:14:55.501622723+07:00 level=info msg=“Starting DB migrations”
logger=migrator t=2023-04-03T13:14:55.504216605+07:00 level=info msg=“Executing migration” id=“add unique index user.login”
logger=migrator t=2023-04-03T13:14:55.610351915+07:00 level=error msg=“Executing migration failed” id=“add unique index user.login” error=“Error 1744: The unique key named: ‘UQE_user_login(login)’ cannot be created because unique keys must contain all columns of the shard key ‘(id)’. See Why do I get errors about UNIQUE KEYs? for details on restrictions on unique keys in SingleStore.”
logger=migrator t=2023-04-03T13:14:55.610422208+07:00 level=error msg=“Exec failed” error=“Error 1744: The unique key named: ‘UQE_user_login(login)’ cannot be created because unique keys must contain all columns of the shard key ‘(id)’. See Why do I get errors about UNIQUE KEYs? for details on restrictions on unique keys in SingleStore.” sql=“CREATE UNIQUE INDEX UQE_user_login
ON user
(login
