It’s v.7.5.7 -
I want to make toggle button to change the pie chart to another pie chart. -
I wonder whether it is possible to make it. - What happened?
I searched a lot but could not find the way. - What did you expect to happen?
Add toggle button on grafana - Can you copy/paste the configuration(s) that you are having problems with?
I want to know if there is toggle button function in Grafana. - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Nope. - Did you follow any online instructions? If so, what is the URL?
I cannot find the document.
I Would highly encourage you to upgrade to latest version of grafana. any reason you are still on 7.5.7?
For what you want this amazing plugin might work out. Read doc and watch videos
Thanks for your reply. It seems that v.7.5.7 doesnt work for these. I think to upgrade Grafana would be more effective. I will try it with your advice. Thanks a lot.
