Is it possible to install AWS cli inside K6 official docker image
building new docker image based on K6’s official docker image to run across multiple CICD workflows.
FROM grafana/k6
# copy k6 test script
COPY dist/test.js /app/
COPY dist/test.js.map /app/
# set working directory
WORKDIR /app
# Here need to run aws cli command to extract secrets from AWS SecretsManager and pass them via -e flags
# CMD ["run", "test.js", "-e", "secret=MyBigSecret"]
However before running k6 script, need to extract secrets from AWS SecretsManager which is used inside of k6 test script.
I can extract secrets and pass them with docker run command as env variables, but this requires to update more than 20 CICD workflows and expose those details, all I want to bake into single new docker image without exposing details.
or is it possible to create a node docker image and install K6 there?
Found this example, however it will throw error Error: Cannot find module ‘k6’
FROM node:14.7.0
#Install K6
WORKDIR /tmp
ADD https://github.com/loadimpact/k6/releases/download/v0.27.1/k6-v0.27.1-linux64.tar.gz /tmp/k6-v0.27.1-linux64.tar.gz
RUN tar -xzf k6-v0.27.1-linux64.tar.gz
RUN mv k6-v0.27.1-linux64/k6 /usr/bin/k6
#Install NPM dependencies
COPY loadtest-home /loadtest-home
WORKDIR /loadtest-home
RUN npm ci
ENTRYPOINT node index.js
Hi @markus,
welcome to the community forum :tada:
Unfortunately not. The current Docker image has the goal to be as light as possible and general purpose where adding a CLI for a dedicated service doesn’t respect these principles.
Yes, it is the solution you should look into.
You should update your k6 version, v0.27 is a very old version. Where did you find this example? In the documentation?
Can you report what the command that RUN npm ci executes is, please?
I hope it helps.
