InfluxQL Aggregration shows too high value
    V9.2.4 as an Home Assistant add-on running on Debian with InfluxDB v1.8.9. as docker on Synology NAS using influxQL.
    Use a subquery to sum measurements and then aggregate/group by 1 hour
SELECT max("SOU") + max("GF") + max("US") + max("GUEST") FROM
( SELECT max("value") AS "SOU" FROM "kW" WHERE ("entity_id" = 'heater_meters_sou_power') AND $timeFilter GROUP BY time(1m) fill(null) ),
( SELECT max("value") AS "GF" FROM "kW" WHERE ("entity_id" = 'heater_meters_gf_power') AND $timeFilter GROUP BY time(1m) fill(null) ),
( SELECT max("value") AS "US" FROM "kW" WHERE ("entity_id" = 'heater_meters_us_power') AND $timeFilter GROUP BY time(1m) fill(null) ),
( SELECT max("value") AS "GUEST" FROM "kW" WHERE ("entity_id" = 'heater_meters_guest_power') AND $timeFilter GROUP BY time(1m) fill(null) )
GROUP BY time(10m) fill(null)
Using other fill() options does not help.
  • What happened?
    On 14:33 it can be seen that the sum of the 4 values is 16.3, which is the highest in that hour.
    Still, on 14:30 the aggregated sum value is 20.7.
    That the sum value shows 16.3.
    Or, that I understand what I’m doing wrong :innocent:
    See above.
    No.
    No.
Any help is greatly appreciated!
(PS I have searched, but couldn’t find an existing topic)
You have grouping by 1m in subqueries and 10m in main query but your question is by 1 hour
Hi yosiasz, thanks for the quick reply.
The subquery is per minute, since I want to sum per minute.
The main query GROUP BY should have been indeed per hour, the 10 minutes was for “debugging”.
Did some more investigation.
Different data source, but still see a weird thing:
Summung up from the first graph I get to 30, but in the second graph it shows 50…
If your time stamp utc?
“Default” = UTC+1
Minimum 20 characters.
In influx db is what I meant :slight_smile:
Also why are you using spread
The data is an increasing energy consumption, so I use spread to get the difference (consumption) per “bucket”, in this case 1 day.
Is this incorrect?
I’m assuming it’s in UTC since after some googling it seems that’s the default and AFAIR K haven’t changed it. How can I check?
