Influxdb2: Combining last + sum to get weekly values
Hi @dieterlind
Several problems to attack, but let’s first focus on why the calculated weekly amounts are off by 1 day. How does adding the timeshift function as shown in the location below affect the results?
import "timezone"
option location = timezone.location(name: "Europe/Berlin")
from(bucket: "iobroker")
  |> range(start: -1mo)
  |> timeShift(duration: -1d)
  |> filter(fn: (r) => r["_measurement"] == "HausverbrauchKwh" and r["_field"] == "value")
  |> aggregateWindow(every: 1d, fn: last, createEmpty: false) // calculates the amount per day using the spread
  |> aggregateWindow(every: 1w, offset: -3d, fn: sum)  // sums the 7 days of each week to get the total used per week
if the above is still wrong, is it off by 1 day still, or perhaps 2 days? Maybe a positive value instead?
    |> timeShift(duration: 1d)
EDIT: Another idea is to skip the timeShift function entirely and adjust the second aggregateWindow function to be as follows:
|> aggregateWindow(every: 1w, offset: -3d, fn: sum, timeSrc: "_start")
Result with -1 day:
Result with -2 days:
Result with +1 day:
Conclusion:
Figues stay the same, just the labeling on the x-axes changes by days of timeshift
Can you try the above instead?
If even that does not work, add the same timeSrc parameter to the other aggregateWindow function, i.e.
  |> aggregateWindow(every: 1d, fn: last, createEmpty: false, timeSrc: "_start") // calculates the amount per day using the spread
To get the values “including today”, this should work:
import "date"
import "timezone"
  |> range(start: -1mo, stop: date.truncate(t: v.timeRangeStop, unit: 1w))
You might need to play around with the time picker, as it may try to override your start or stop time. Try to make it a wide window. Here is some test data (only contains 6 days or so) that correctly sums through today:
applying the timeSrc brings a really good result:
now “just” the labeling of the bar is wrong. Last bar should be 12.6., penultimate 5.6., …
if I apply the range-extension I get an error:
import "timezone"
Error:
Did you remember to include at the very beginning of your query this line:
import "date"
For the above, how about changing the offset to -10d?
|> aggregateWindow(every: 1w, offset: -10d, fn: sum)
regarding the error: yes, sorry, forgot to import date
then result is:
vs. without the stop-clause:
so just the last bar changes
when I set the offset to -10d actually nothing changes …
with this version of the flux I am almost happy:
import "date"
import "timezone"
  |> range(start: -1mo)
Result:
The only thing I don’t like that the date of the bars is actually always one week delayed (except last bar from today). So everything should be the monday of the week start.
Alternative: Is there the possibility to display the time range covered in the bar (.e.g for the penultimate bar: 12.6. - 18.6.)??
You noted the above conclusion when playing around with the timeshift function in your query. If the only problem remaining now is the labels on the bars (i.e. one week delayed), shouldn’t this help?
|> timeShift(duration: -7d)
thanks again for your support
with:
import "date"
import "timezone"
  |> range(start: -28d, stop: date.truncate(t: v.timeRangeStop, unit: 1d))
I get
Which is perfect for the last 4 weeks
But what I am missing is a bar for the current week starting with today …
If I remove the stop-clause in range I get
Which is value-wise OK, but date-wise wrong (should be 19th)
Do i have to add a second query for the current week (actually I tried to do so, but didn’t manage to make it)
Hi @dieterlind
OK, I feel you are getting close!
What value in the Grafana times picker is timeRangeStop? I presume it’s ‘now’?
There is even a chance that tomorrow (Tue) you will get a ‘partial’ brick for the current week (starting with June 19) which should grow each day of this week.
Yes, to is set to now
I added now a second flux for today
import "date"
import "timezone"
  |> range(start: date.truncate(t: v.timeRangeStop, unit: 1d))
But i think that one will just work today and not tomorrow …
But the result is perfect
See what happens tomorrow (Tue). We are truncating the stop time to the nearest day and Monday has not yet finished.
Hi @dieterlind
How does the graph look today?
Unfortunately not too good:
With these 2 flux:
import "date"
import "timezone"
import "date"
import "timezone"
the 2nd flux brings the last bar, the 1st flux the other bars
Hi @dieterlind
Let’s try going back to one query only. Does changing the stop value in the range() function as follows help?
import "date"
import "timezone"
import "date/boundaries" // need to import this to use the next function
thisWeek = boundaries.week()  // define thisWeek
  |> range(start: -28d, stop: thisWeek.stop)
wow … it seems that the change in stop was the trick (here fore 28 days)
When I change it to 1 month I get:
Which is value-wise correct.
The question is: can a get rid of the first bar (15.5.), as it is just one day of a week and reduce it to the last full 4 weeks + the current week??
Alright @dieterlind, I think this 8+ day journey is about to cross the finish line…
How about this?
import "date"
import "timezone"
firstWeek = boundaries.week(week_offset: -4) //  may need -5 here....not totally sure
  |> range(start: firstWeek.start, stop: thisWeek.stop)
  |> aggregateWindow(every: 1w, offset: -3d, fn: sum)  // sums the 7 days of each week to get the total used per week, and use -3d as the offset to move the weekly aggregate to start on a Monday
  |> timeShift(duration: -7d) // needed to get the weekly labels correct
