InfluxDB/Grafana regex URL
Granfana v7.4.3, self-hosted Grafana
Hello
I am a newbie with Grafana and I have
influxDB field ‘job.trigger’ with values like ‘Triggered by Gerrit: https://gerrit…/+/77777 in silent mode.’
In grafana dashboard I am trying to set direct link to gerrit commit
Panel Options/Name Pattern/job.trigger.
Link/url/https://gerrit…/${__cell:raw}
The question is how can I grab link from field to form correct url?
Just now I have something like this https://gerrit…/Triggered%20by%20Gerrit:%20https://gerrit…/c/carbon-ui/+/77777%20in%20silent%20mode.
Thanks!
welcome to the :grafana: forum, @uarhodesian
If you are a newbie at grafana, then I highly recommend using the newest Grafana. Version 8 is far more advanced than version 7, and there have been many improvements to data links
If so, then you could try and use regex-based value mapping + data links (maybe?). Either that or isolate the data inside that string on the DB side before it reaches Grafana…?
