9.3.0 - What are you trying to achieve?
check alert history using api - How are you trying to achieve it?
using api → /api/annotations? - What happened?
I use api for checking alert history.
After upgrade grafana from 9.0.0 to 9.3.0, can’t see recent alert information anymore.
i tried add new alert, restart grafana. But it worked same.
if i add annotation from other dashboard, i can see from api result. (fisrt row)
so i consider there’s some kind of error or that api doesn’t show alert information anymore.
but i can’t sure which one is the root cause
