I’m new in plugin development, so I start using some off the grafana-ui components. In this case, the Simple Button: https://developers.grafana.com/ui/latest/index.html?path=/story/buttons-button--simple.
This component has to import some dependences, so I took the grafana-ui folder from GitHub and put it at the root of my project using the same structure:
package/grafana-ui/src/...
Actually, I don’t know if it’s the right way to do it
But I can’t import Button.mdx
import React from 'react';
import { select, text, boolean } from '@storybook/addon-knobs';
import { Button, ButtonVariant } from '@grafana/ui';
import { withCenteredStory, withHorizontallyCenteredStory } from '../package/grafana-ui/src/utils/storybook/withCenteredStory';
import { getIconKnob } from '../package/grafana-ui/src/utils/storybook/knobs';
import mdx from '../package/grafana-ui/src/components/button/Button.mdx'
import { ComponentSize } from '../package/grafana-ui/src/types/size';
Thanks for helping!
