Implementing alerting on custom plugin
Hi!
I’m developing a custom plugin based on the simple Json plugin.
The base plugin doesn’t appear to have support for alerting.
I’m trying to understand how much effort it’ll take to implement it on my own, and where should I look.
Any suggestions?
I am do the same thing,have some evolve?
Did either of you (@ittai / @wanyongx) have any success developing a plugin to have support for alerting? I am debating on tackling the same task for the OSIsoft PI plugin.
Actually, I just found this: (How can I make alerts work with my custom datasource plug-in? What should I make in the backend?) and it has a couple of examples. I’m going to check those out and see what I can find.
