10.3.1
Ubuntu 20.04.06 LTS -
Having user depend parameters for a datasource (currently using MySQL), which cannot be changed by the user.
Removing the query from the network traffic (only the parameters should be sent to the server). -
Running the queries within an api, but I have problems with audentify / identify a user at a JSON API data source.
I tried to forward the auth to the api, but only thebasic-authsetting gets forwarded. -
What happened?
Only thebasic-authset in the datasource settings are being forwarded. TheForward OAuth Identityis not being forwarded. Do I have to change the authentication of grafana? At the moment the authentication is unchanged. -
Some kind of token gets forwarded, that may be used to identify the user with the grafana api.
Basically I want to change the datasource in a way, such that the user cannot change specific parameters.
Additionally I would like to hide database structure, but that should be possible my executing all queries within an api.
Thanks in advance
