What Grafana version and what operating system are you using? Ubuntu 22.04, Grafana 10.4.2
What are you trying to achieve? Configure the IBM QRadar plugin
What happened? Keep getting “check your host, port, SSL certificate, or authorized service token” error
Hey there!
I’m on Ubuntu 22.04 with Grafana 10.4.2. Trying to set up the IBM QRadar plugin but keep getting a “check host, port, etc.” error.
Just followed the online instructions but something’s not right.
Haven’t seen any errors in Grafana itself, but maybe the logs have something.
Could you please share more details about this.
