We want to send alerts from Grafana(Ordinary Grafana not the Enterprise or Cloud one) to the HMI machines which are not support any internet connection or even Ethernet; and they use MQTT channel.
For this issue in summary I found these steps:
1- sending an alarm from grafana using MQTT plugin in order to easily handle it in the HMI:
that could be the best one but MQTT plugin doesn’t support Alerting! And after reviewing all aspects, it won’t possible.
2- using webhook and MQTT broaker:
This one also can cover Rest API but for translating HTTP request to MQTT we have to use Node-Red (or if there is any other way) as a solution so it may takes some time to figure out.
3- sending alert to Prometheus Database
4- using Infinity, Json or HTTP Plugins
beyond these 3 plugins just Infinity is supported by Grafana Alerting but the point is we have to use .json file and our alerts are .yaml, so we have to find a mechanism to convert it.
I really appreciate if someone have a contact with me about that.
