V9.3.11 -
I’m trying to use the result of a query in an html table using plugin named aidanmountford-html-panel
The result of my query is just a date value
- How are you trying to achieve it?
I’m trying to use the event onInit
- What happened?
I’m not able to find by myself how to get the result of my query in a javascript variable
Could someone could help me ?
I’m a dummy on grafana ![]()
In advance thanks for your help
best regards
Marc.
