Grafana v9.2.1 | macOS Sonoma 14.2.1 -
To create a third panel that indicates which of the other two panels’ values is greater. -
What happened?
To say “yes” or “no” if the first panel is greater than the other. -
I’m using Infinity data source and stats panels.
