How to store configuration for an app plugin?
I am trying to build an App Plugin for Grafana 8 onwards in React and I found the repo with the tutorial and the simple app.
I am having a trouble though and it’s about saving/loading configurations. I tried searching around to find a way to save a configuration in a file or in any place possible but I was not successful (looked into local file as in the plugin directory). I am trying to avoid querying a server or external system for a json with the config.
Which is the recommended way to store a configuration for an app plugin?
If anyone ever needs a little help at this, what I did was:
created a function that sends a post request with the settings as
updatePluginSettings = (settings: { jsonData: unknown; pinned: boolean }): Promise<undefined> => {
        return getBackendSrv().post(`api/plugins/${this.props.plugin.meta.id}/settings`, settings);
Later you can read the settings as:
this.props.plugin.meta.jsonData
