Is it possible to use something like Blob in K6, in order to have form data elements with different content types? i.e one is a file (easy enough), another is json. Each would have their own respective content types.
Something like:
const fd = new FormData();
fd.append('bookInfo', new Blob([JSON.stringify({
quantity: "12"
type: "application/json"
fd.append('testFile', http.file(someFile, 'somefil.txt', 'application/octet-stream'));
Hi @jclarknet, welcome to the forum and sorry for the slow reploy
It seems to not have been documented but you can just append an object with keys:
- data - which will be the data you want
- filename - you can skip that if you don’t want filename set.
- content_type - with the content type you want, if not provided it will be
You can see it done here
Hi, did you find a solution for this? because I am facing the same problem, I followed the solution provided by @mstoykov , which worked but I got an error , I will add my code here as well.
fd.append("version", number);
fd.append("file",{data: new http.file(binFile), filename: 'test.bin',content_type: 'application/octet-stream'});
fd.append("firmwareId", "b5b51538-72b2-433f-b873-d65abf04b4b2");```
OUPUT:
execution: local
script: tester.js
output: -
scenarios: (100.00%) 1 scenario, 1 max VUs, 10m30s max duration (incl. graceful stop):
* default: 1 iterations for each of 1 VUs (maxDuration: 10m0s, gracefulStop: 30s)
INFO[0017] number of devices: 1 organizationName: Pr Organazation t1 source=console
ERRO[0018] Uncaught (in promise) TypeError: Value is not a constructor
✓ status code: 200
Hi @Zahida.Parveen,
This topic is 1year+ old and unlikely to get a new response.
Also, your errors seem unlikely to be directly related to the topic at hand.
I would recommend opening a new topic with more info in order for somebody to be able to help you.
Hey @Zahida.Parveen , it’s been a while since I wrote this, but below is the code that worked for me:
fd.append('someFile', http.file(someFile, 'myfile.bin', 'application/octet-stream'));
const res = http.post('https://someurl', fd.body(), {
headers: { 'Content-Type': 'multipart/form-data; boundary=' + fd.boundary },
