Describe the bug
It seems that excluding logs in a pod using the configuration below does not work:
loki-stack-values-v2.4.1.yaml:
loki:
enabled: true
config:
promtail:
enabled: true
extraScrapeConfigs:
- job_name: kubernetes-pods-name
pipeline_stages:
- docker: {}
kubernetes_sd_configs:
- role: pod
relabel_configs:
- source_labels: [__meta_kubernetes_namespace]
action: drop
regex: kube-system
- job_name: kubernetes-pods-direct-controllers
pipeline_stages:
- docker: {}
- role: pod
relabel_configs:
action: drop
regex: kube-system
- job_name: kubernetes-pods-indirect-controller
pipeline_stages:
- docker: {}
- role: pod
relabel_configs:
action: drop
regex: kube-system
- job_name: kubernetes-pods-static
pipeline_stages:
- docker: {}
- role: pod
relabel_configs:
action: drop
regex: kube-system
fluent-bit:
enabled: false
grafana:
enabled: false
prometheus:
enabled: false
To Reproduce
Steps to reproduce the behavior:
Deployed helm loki-stack :
helm install loki grafana/loki-stack --version "${HELM_CHART_VERSION}" \
--namespace=monitoring \
--create-namespace \
-f "loki-stack-values-v${HELM_CHART_VERSION}.yaml"
Attach grafana to loki datasource
Query: {namespace=“kube-system”} in Grafana Loki
RESULT:
See logs of kube-system
Expected behavior:
Not seeing any logs of kube-system
Environment:
Infrastructure: kubernetes
Deployment tool: helm
Maybe i’m missing something, help would be appreciated!
