How to set empty header in K6
for one of the custom headers, I need to set it to an empty value. Somehow I am not able to.
I tried setting it to “”, " ", ‘’, ’ ',``, , null, undefined but still I don’t think it’s working.
To give a reference in RobotFrameworks, there is a defined value called {EMPTY}, when I set header to this empty value it works through robot frameworks.
Is there something similar in JavaScript?
This is how I am setting my header :
const custom_header = {
headers: {
'Authorization': __ENV.Token,
'Content-Type' : 'application/json',
'bID' : ""
if I set it to bID: undefined or bID : null then also it shows that its set as bID: [“null”] or biD: [“undefined”]. How do I set it as bID: []
please suggest.
Hi @Jay
Let me try to help you!
I believe passing the empty string should work. To prove that, you can try the option --http-debug, which can enable logging of all HTTP requests and responses. For example, if I run something like:
k6 run --http-debug=headers test.js
// test.js
import { sleep } from 'k6';
import http from 'k6/http';
export default function () {
  http.get('http://127.0.0.1:8085/', {
     headers: {
        "header1": null,
        "header2": '',
        "header3": "",
        "header4": undefined,
        "header5": "something"
  sleep(1);
I’ll see in the logs the following request details:
INFO[0000] Request:
GET / HTTP/1.1
Host: 127.0.0.1:8085
User-Agent: k6/0.35.0 (https://k6.io/)
Header1: null
Header2:
Header3:
Header4: undefined
Header5: something
Accept-Encoding: gzip
Let me know if that helps,
Cheers
Thanks for the response. When I set it to opening and closing quotes, the --http-debug flag doesn’t show it but I print the response object which prints the headers used to send the particular request where header is shown like this {“BId”:[“”]}, where as I expect it to be {“BId” : [ ]}
where as I expect it to be {“BId” : }
The thing is that the headers are just key/value pairs of the strings. And the typical way to pass multiply values is comma-separated value, like:
X-HEADER: ab,cd,wx,yz
So, interpreting the value as the array is the responsibility of the server-side. If your serverside is expecting to constantly parse value like [] in the header, you can try this:
     headers: {
        "header_empty": "[]", // it's a string
        "header_filled": ["one", "two"], // this will be converted to a CSV
        "header_filled_the_other_way": "[\"one\", \"two\"]",  // it's a string again
Which produces this:
GET / HTTP/1.1
Header_empty: []
Header_filled: one,two
Header_filled_the_other_way: ["one", "two"]
Let me know if that helps!
