Currently I am running a single instance of Loki on Linux, since our production env hit single node limit.
We are running Loki as a service, please let me know how we can scale it.
Please see Loki deployment modes | Grafana Loki documentation.
Things to watch out for:
Thank you so much Tony, Yes your correct.
I have read this deployment mode article, but I didn’t find any detailed documentation for this. It will be great if you can guide me how to achieve this task.
Thanks in Advance.
I don’t run Loki on physical servers, so I can only give you some rough ideas. But before you consider doing that, remember you’ll need some sort of storage that all your Loki nodes can access as backend storage. If you are running onpremise this usually means minio. You can use NFS too, but I suspect you’d get much worse performance with NFS.
loki1.local) that points to the nodes you created. This is for service discovery, so the DNS record needs to point to all nodes. For example:loki1.local. 60 A <node1 ip>
loki1.local. 60 A <node2 ip>
memberlist:
<OTHER_CONFIG>
join_members:
- dns+loki1.local:<GOSSIP_PORT (default 7946)>
That’ll give you a cluster. the rest is making sure all your nodes are configured the same way, and can get access to the backend storage.
Hey, thanks a lot Tony, I have deployed the multiple instances on different servers, Since I am using latest Loki version. I need pass member details at service level. Although everything looks fine but when I am trying to check the logs in Grafana I am able to see only logs transferred from loki1. why is that? it should so both the Loki data.
Below is the current
service file for Loki1 running on host1
[Unit]
Description=Loki service
After=network-online.target
Wants=network-online.target
[Service]
Type=simple
User=loki
ExecStart=/usr/bin/loki --config.file /etc/loki/config.yml
# Give a reasonable amount of time for the server to start up/shut down
TimeoutSec = 120
Restart = on-failure
RestartSec = 2
[Install]
WantedBy=multi-user.target
service file for Loki2 running on host2
[Unit]
[Service]
Type=simple
User=loki
ExecStart=/usr/bin/loki --config.file /etc/loki/config.yml \
--memberlist.bind-addr='host1-IP' \
--memberlist.bind-port=7946
TimeoutSec = 120
RestartSec = 2
[Install]
WantedBy=multi-user.target```
Not quite sure what you mean by this.
Check /ring endpoint on your Loki instance to verify a cluster is formed.
Hello Tony,
On my both instance I am getting this message.
ring endpoints are also just showing itself.
Below is my config file.
auth_enabled: false
server:
http_listen_port: 3100
log_level: debug
common:
instance_addr: 127.0.0.1
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
kvstore:
store: memberlist
memberlist:
node_name: loki-node-61
join_members:
- hostip:7946
ingester_rf1:
enabled: false
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
schema_config:
configs:
store: tsdb
object_store: filesystem
schema: v13
index:
prefix: index_
period: 24h
pattern_ingester:
enabled: true
metric_aggregation:
enabled: true
loki_address: localhost:3100
ruler:
alertmanager_url: http://localhost:9093
frontend:
encoding: protobuf
In order to join two nodes into a cluster, you’ll need a DNS record with two values, pointing to both of your instances, then use service discovery to join them into a cluster. Please review my replies further above, I believe I did put down something on this.
