How to remove/modify the description of the plugin?
I’m currently using Grafana plugin tools to create a plugin.
I’ve set up name, org, description and others following the prompts after the very first command
npx @grafana/create-plugin@latest
I’m working on the plugin for a while now. However, I want to change the description of my plugin. Searched many places, still couldn’t find where the initial settings of the plugin are. Any suggestions how i can change the description?
Thank you!
Hey @huiminmu - you can change it by editing the content in src/plugin.json and the “description” field.
Here’s the reference for the plugin.json in our docs - plugin.json | Grafana documentation
Hello @davidharris - Thank you so much for your help! It works now.
No problem at all - best of luck!
