export scenario1 fundefault () {
mutation {
client(
I want to run a scenario with 10vus, 10iterations.
by first send id=1
and second send id=2
10th send id=10
please recommend me thank you!
mutation {
client(
by first send id=1
10th send id=10
Hi @Pamorn,
Right now it sounds to me like you might find execution API useful: to set id
in mutation equal to VU’s index, execution.vu.idInTest
. In case it is something else, could you please add what k6 script you tried and what exactly didn’t work?
thank you for your reply.
you’ve got a point. but I can’t apply execution.vu.idInTest
to my code could you pls take a look for me
type or paste code here
import { sleep } from 'k6';
import { SharedArray } from 'k6/data';
import { vu } from 'k6/execution';
const users = new SharedArray('Operators', function () {
return JSON.parse(open('user2.json'));
export const options = {
scenarios: {
login: {
executor: 'per-vu-iterations',
vus: users.length,
iterations: 2,
export default function () {
console.log(`InsertOperation: ${users[vu.idInTest - 1].name}`);
sleep(1);
const InsertOperation = `
mutation {
InsertOperation(
OperationName: "a"${users[vu.idInTest - 1].name}"!"
result here
scenarios: (100.00%) 1 scenario, 10 max VUs, 10m30s max duration (incl. graceful stop):
* login: 2 iterations for each of 10 VUs (maxDuration: 10m0s, gracefulStop: 30s)
INFO[0000] InsertOperation: undefined source=console
INFO[0001] InsertOperation: undefined source=console
running (00m02.0s), 00/10 VUs, 20 complete and 0 interrupted iterations
login ✓ [======================================] 10 VUs 00m02.0s/10m0s 20/20 iters, 2 per VU
data_received........: 0 B 0 B/s
data_sent............: 0 B 0 B/s
iteration_duration...: avg=1.01s min=1s med=1.01s max=1.02s p(90)=1.02s p(95)=1.02s
iterations...........: 20 9.826967/s
vus..................: 10 min=10 max=10
vus_max..............: 10 min=10 max=10
my user2.json file
{ "OperationName": "a01!" },
{ "OperationName": "a02!" },
{ "OperationName": "a03!" },
{ "OperationName": "a04!" },
{ "OperationName": "a05!" },
{ "OperationName": "a06!" },
{ "OperationName": "a07!" },
{ "OperationName": "a08!" },
{ "OperationName": "a09!" },
{ "OperationName": "a10!" }
I try to cut “${users[vu.idInTest - 1].name}” from “OperationName”${users[vu.idInTest - 1].name}“!” it’s work but that what I try to do.please point my error.
@Pamorn, with this JSON file, users would contain Objects with the key OperationName
, not name
. So using the following:
console.log(`InsertOperation: ${users[vu.idInTest - 1].OperationName}`);
should print a defined and expected result, e.g.:
INFO[0000] InsertOperation: a09! source=console
INFO[0000] InsertOperation: a04! source=console
INFO[0000] InsertOperation: a02! source=console
INFO[0000] InsertOperation: a03! source=console
INFO[0000] InsertOperation: a06! source=console
INFO[0000] InsertOperation: a01! source=console
INFO[0000] InsertOperation: a05! source=console
INFO[0000] InsertOperation: a08! source=console
INFO[0000] InsertOperation: a07! source=console
INFO[0000] InsertOperation: a10! source=console
I also think that InsertOperation
can be a bit simplified, down to:
mutation {
InsertOperation(
OperationName: ${users[vu.idInTest - 1].OperationName}
Would these changes be sufficient for your use case?
yes! it works thank you!
