Grafana v9.3.6 -
I have deployed a Grafana helm chart with ansible. I have avalues.yamlfile that follows the same structure as this.
By default, Grafana uses my browser’s timezone (UTC+2) for everything timestamp related.
I want to configure it so that it uses UTC as the default for all users on the dashboard, that way I don’t have a 2 hour offset between the timestamps in Grafana and the timestamps in my datasource.
Where can I do this in thevalues.yamlfile? I know it can be normally done in agrafana.inifile but since I am only using a yaml file for the configuration I am not sure how to achieve this.
Thank you in advance!
